white-t-type
- Oct 13, 2008
I recently removed my engine for a rebuild. Today I finished up connecting all the wiring and prepared everything for break in. I set the cam sensor as directed on gnttype website, however I am not getting any spark and my fuel pump is not coming on with the key. Any ideas something I could have missed? What can I look for? I know I plugged up the injector harness, ecm orange wire, crank sensor, tps, iac, maf, the 3 prong switch at the bottom side of the block on the passenger side as well as the coolant temp sensor by the top of the intake. EGR has been blocked, and I am using a RJC boost controller instead of the stock solenoid. When setting the cam sensor I could not get any higher than 4.85 volts, and when I turn on the key I do not get a check engine light, it never illuminates. Basically the motor will turn over but not fire, even if I run a jumper wire to make the fuel pump run it will not fire. I am going to walk away from it tonight and try again in the morning. Any help would be appreciated.
