I have been able to spend a lot of time at the track lately, not to give anybody track envy, but the tack is 10 miles from my house. Yesterday I got in on a track rental thanks to a heads up from HighMileage. Track rental is like being a kid on Christmas morning.
I left everything the same from the previous track runs, and with the temperature change and possibly the car being hotter also for the first run, I got a little more knock then I like to see. 4.7 degrees at the 1-2 shift. And a few blips down the track between .5 and 2. Added fuel, and cut it way down. Added a little more and turned alky to 6.5 and cut it to I think one blip of .5 at 95. (still need to get a powerlogger).
Best run:
1.729
7.960@85.37
12.585@105.77
Without better breaks or airbag or …, I don’t think I can cut a better 60ft.
I also don’t think I can get too much more mph without some work.
I am interested in possibly porting everything, just to see what it may net. I’ve seen the sticky on porting the stock stuff and may go that route.
Does anybody think porting the stock heads will net anything with the stock setup? Cracking the factory head gaskets may not be worth it though. (could be a winter project, I would like to pull the engine anyway and replace all of the gaskets just to get rid of as much oil seepage as possible and make it look nice)
I know the stock downpipe is a big restriction with bigger turbos, any real value with the stock turbo?
I am leaning towards just cleaning up and optimizing all of the factory stuff, not because I’m cheap, just for the fun of it.
Also, is anybody running the stage 1 extreme automatics transmission with their replacement valve body? Thinking of putting one of these in over the winter. I like it because no core required, put the stocker on the shelf, swap in the new one?
Best run:
1.729
7.960@85.37
12.585@105.77
