The Granny
- Sep 30, 2015
I wired up the alky kit per the instructions provided, yet I'm still running into issues. Everytime I turn the ignition on the 15 AMP fuse blows. Car is reading 4.8V on the MAP sensor with KOEO. I've changed the grounds on the pump and still no change. If I disconnect the power to the PAC the car starts normally, otherwise it won't. Had the PAC sent to Julio and it checked out ok. If I disconnect the wires from the PAC to the pump it still blows the fuse. I disconnected the 6 pin connector and it still blew the fuse when I tried the ignition. I ungrounded the PAC and the fuse didn't blow. Changed the ground to a different location and it blew. Thanks in advance for any help. I'm looking to get this solved before I head back out of town tomorrow evening
