I am having to make some gaskets for my DP to exhaust side of my turbo and have some hi heat gasket material with a thin layer of metal in between the gasket materital. I know I can use tin snips for the rough outlineof the gasket but what do you think would work on the turbine outlet and wastegate? I already figured on a drill bit for the Dp holes.
