turbo415707
- Aug 16, 2014
Is the red line 20/50 oil any good for our cars any experience with it?
SignUp Now!X2 10/30, no need for the 20/50 unless you have bearing clearance issues.No need for synthetics,Brad Penn or Valvoline VR! works good and less $$$. Stay away from 20/50, 10W/30 is usually the best for our cars.
I'm curious as well. Is this repetitive internet info or legit fact? My go to guy for these cars has been working on them for 20+ years and told me 20/50 is the way to go. Never ran anything else in mine.To make a blanket statement to "stay away from 20W-50" would need to be based upon specific facts to verify why?
I posted this somewhereIs the red line 20/50 oil any good for our cars any experience with it?
Is your short block original and never been touched?Is the red line 20/50 oil any good for our cars any experience with it?
IMO syn's always tend to seep and leak more and not needed. I do think the oil cooler is needed and is there for a reason. I run DINO 20w50 mostly but have also ran 10w30. Did run the VR1 Syn last year just because I got a stupid great deal like 1.98 a qt so I bought a ton and used it but noticed the rear main starting to seep after swapping over to it.
Dont get wrapped in oil psi in gear fully heat soaked that it needs to but high. 15ish -25ish is the NORM!! And oil psi should rise approx 10 psi per 1K rpm rise with the yellow spring thats around 50ish -65ish at WOT 5200-6000 rpm
These are the ranges IMO that are the norm.
Also redline, Amsoil (AKA scamsoil lol), etc are expensive and with a turbo engine the blow by contaminates are greater and once they are in suspension the oil needs to be changed. In other words...more frequent oil changes syn or not. Its your wallet
I assume that is your opinion which is based upon your personal experience with stock engines or ?
Having dealt with hundreds of Buick performance engines and seen many that have had bearing issues, it is usually rod bearings that are trashed due to detonation or too tight clearances.
Since we use 20W-50 oil and recommend it, we have never seen an issue due to clearances in our engines, but we do NOT use factory specs since we are doing a performance build, not an economy car build.
We are talking performance here, not grocery-getting, so the conditions of HP and RPM are much different.
My personal experience with many engines in my various TR's with thousands of passes, I have never trashed a rod or main bearing with any engine we have built, and always use 20W-50 oil.
To make a blanket statement to "stay away from 20W-50" would need to be based upon specific facts to verify why?[/QUOTE
So if I live in a cold climate and set my specs to .0025 you still recommend 20/50? Or just for "your" climate.
