Red's Double Pump Replacement
T-top87GN
The Buick Manual CD Guy
I'm going to be dropping the tank here in the next couple days and figured I should probably change the pumps out while I have everything apart. What replacement pumps are people using? Thanks!
They are both at LEAST 10 years old. I needed to drop the tank anyways so I wanted to change them.
So today I did that. Lucky for me, Red forgot to wipe the numbers completely off of one of the pumps.
For future reference, the XP pumps were Walbro GSS307's.
This reference is incorrect. Even though the number is on the pump, it is not the pump number. I have seen many different numbers on these pumps. Sometimes the number is not ground off by parts supplier.
There is no part number for these pumps as each pump is custom built with 14 mods done to it before assembly by Red. This is why still today, this pump shines above the rest when used as intended.
If the pumps work, leave them.
