reds double pumper
L8TRH8R
Got my new pump in but cannot find the yellow plug that the power for the second pump is supposed to go to. Please help!
I'm looking for the pressure switch that turns the second pump on I guess...
Well its kinda hard to get pictures of... Basically the pump is in the tank and back on the car and running. I have a ground set to the frame for the second pump but have no idea where to route the power wire for the second pump. Reds directions say to go to the allow connector that çomes from the pressure switch. I cannot find that.
There should be a boost sensing switch that comes with it that turns on the second pump. And a led to let you know the pump is on. You have to t off a boost line to make it work.
Maybe thats my problem. There is no boost sensing switch... All it came with was the original type plug and then a red and black wire coming off I assume for the second pumps power. Thats it. Did I recieve a incomplete kit??? :confused: The power wire doesn't just go to the alternater does it? I'm getting:mad:
This is what I recieved in my Red's kit. Are you missing anything from this picture?
does yours look like this see the t there,s your switch and are you useing a hot wire kit you need that to. make the red wire longer and run it to the back of the alt same with the switch make the wires longer to put a vaccum / boost hose on the T and untill you hit 17 psi that second pump will not come on good luck.
Brand new from Red or from another member? If it's new from Red, All you need to do is give him a call and i'm sure he will take care of you.
Scot W.
heck no wounder you are having such bad time ive had mine for yrs love it get the hot wire kit as well
