refrigerator help needed
jetmech
I have a kennmore fridge. top freezer bottom fridge. older unit. the problem is my freezer leaks water into the fridge and puddles up at the bottom. i pulled the drain pan from under the fridge and it dry. Is my defrost tube plugged or is somthing else going on. It's a temp. residence while our house is being renovated.
Either the tube is plugged or there's a crack or leak between the two sections allowing water in there during the defrost cycle most likely.
Obviously finding the water path during defrost out of the freezer would be the first order of business if it's a tube you could try compressed air at relatively low pressure to clear it.
Just my internet guess.
