Relocated using stock hotair accessory bracket
boosted84
Used some creativity and got it to work and it was pretty simple, suprised my self lol bolts up and everything just had to trim and make front of bracket so P.S. could mount flush.
You will have to drill the mounting holes bigger and make a new hole for bottom bolt. there are a few more easy things to do but you will see if you attempt. you will have to shim the crank and waterpump pulley to make it so you can run alt and ps separate with v belts
well im converting it all to serpentine, and spacing the pullys helps even more for me! Again, Good idea! and thanks! Love your colors by the way........
A.j.
I respect what you did here, especially that you shared it with us. But, why didn't you just convert to serpentine?
I would have had to buy :
powersteering pump + Res.
alternator
crank pulley
waterpump pulley
87 acessory bracket + alt mount
idler pulley
tensioner
serpentine belt
My way all i had to buy was longer belt for alternator + some bolts
maybe down the line i will switch to serpentine but what i got works, was easy to do, and saved me some cash for now.
Just an alternative for those who like to tinker too i guess :biggrin:
