Spooled231
 - Jun 21, 2001
I have a set of remote oil filter lines with fittings that I had made at a hydraulic hose assembly shop that I no longer need as the oiling system has changed on my motor.  Asking $50 plus shipping.
These were built for a PTE oil filter relocation kit that is mounted behind the passenger headlight.
The hose is a Weatherhead H42510 (see specs below)
Hose Cover Material : Neoprene
Hose I.D. : #10 (5/8")
Hose Inner Tube Material : Nitrile Blend
Hose Minimum Bend Radius : 8"
Hose Minimum Burst Pressure : 11,000 P.S.I.
Hose O.D. : 1"
Hose Operating Temperature Range : -40 Deg to +212 Deg F (Hydraulic)
Hose Reinforcement Type : 2 Layers Of Hi-Tensile Steel Braid
Hose SAE Rating : SAE 100R2
Hose Type : High Pressure
MSHA Approved : Yes
Series of Hose Ends Used : Coll-O-Crimp S, U, Z & 430USeries, Field Attachable 425N Series
Type : High Pressure Hydraulic Hose (2 Wire)
USCG Approved : Yes
Use : High Pressure Hydraulic Systems, Water / Glycol Systems, Fuel Systems
Working Pressure : 2,750 P.S.I.
Brand Name : Eaton / Weatherhead
Hose O.D. : 1"
MSHA Approved : Yes
USCG Approved : Yes
