- Jun 18, 2001
Yes, they worked.Do the GNX vents actually lower the underhood temps? Or was that a simple styling item and marketing came up with the HP excuse?
Here in Phoenix,AZ. We try to do a lot to reduce the underhood temps. First thing I have done to all of mine is to remove the rear hood gasket on the drivers side. It makes a noticeable difference and is easy to put back when you sell the car. But I figured out quickly that if you want the A/C to work well, you have to leave the gasket on the passengers side to about 2 or 3" past where it sucks air from the bottom of the windshield.
Anyone have any ideas other than the fender vents? It gets to 115 here in the summer!
TIMINATOR
But they're not the best place to put a vent. They just happened to fit with the Buick/Harley Earl side fender vent theme they've had off and on for 60 years.
However, removing that gasket at the base of the windshield is a terrible idea. That area is a high pressure zone when the car is moving. Remove that gasket and air pushes in from the windshield and stalls out the radiator.
I did the testing. On the subject of hood vents | Things I work on
