Removing EGr question
87gn-newbee
Since my chip doesn't use it and no smog checks when I remove the actual egr do I leave the black box/filter I think conected?
Will it set a code if not used?
Dan
If your chip ignores it. No it will not set a code. Best to gut the box and vacuum lines cleans up the engine area nicely. I would leave the EGR bolted to intake unless you are going to use a block-off plate. :cool:
no checks and I have a block off plate. I just thought with it unplugged might set a code or SES light. Thanks
Dan
ECM will only check for egr working if EGR is activated. If chip is zero'd out, then no problem.
Tom
Stock look--A couple of ball bearings or bee-bees in the vacuum line going to EGR. No mo worky.
Mitch
