That is exactly what I am trying to do...arrive at a more equal flow for tuning and high boost safety measures than the Hemco alone can achieve. I understand Brian's point about the Hemco but I would like to try some new technology and see if it makes a differnece. Thats all.
Ed,
Think of it as a 4BL manifold. The optimal design is to dump air into the center of the plenum. Perfect would be a pipe straight into the plenum, rather than a '90' as our upper plenums do. Unfortuanatly, due to underhood fitment issues this is not possible.
The Hemco drops the air directly into the center to be distributed equally.
The smaller opening does make one question the actual usefulness of this plenum. But, upon installation of every one I have installed fuel pressure had to be raised due to the motor running leaner. (more air)
Years ago Red Armstrong did not believe the worked either. Janes car was run at White Racing on their dyno fo actual testing. Needless to say, 40 hp on her car. That was around 620 at the wheels.![]()
These plenums may look pecular, but the undoubtably work.
My original offer still stands though.![]()
Ed, I am sure whatever you decide, will be best for your car`s combo.
The plates must work, as RJC sells a bunch of them. My experience goes back to installing my first one. I never looked back. Or around for that matter.
Brian
