this must be old news to many of you on this board. recently replaced the the front end bushings, springs, and shocks on 86t. wow, that job is a hard day of work.
had to go medieval on the A-arms to get the old bushings out; cut sections out of the bushing with sawzall, then pounded out shells with punch. this was slow, but worked ok until we hit the lower A-arm on pass side that had hardened metal inner sleeves (maybe someone wrecked the original A-arm?). those sleeves mocked the sawzall blades until we got out the abrasive grinding wheel.
the steering and handling is soooo much better! amazing difference. can't wait to do the rear end and body bushings.
