SignUp Now!Basically I have a ground wire running from the block into my ecm case. Also connected to that same spot is the wideband ground. At key on after the car has sat for a long time it reads 14.5, moves up to about 16.0 for few seconds then continues on up to 19.99. Is that what you're asking?dave, where is your PLX grounded?
what does the PL show the AFR is while the PLX is warming up?
Bob
My issue is an unusual offset. When I have narrowband tracking active and the target is 14.5, the wideband is reading 15.3ish. I believe its been doing this for a few years. Even when I was running translator pro.That sounds like it's working. When my sensor was bad it would not go above 14.5. New sensor went to 19.99. http://www.plxdevices.com/support/manuals/SM-AFRGen2UsersGuide.pdf
Sent from my QMV7A using Tapatalk
Did that this morning, at that checks out.pretty much, another test is to start the car and look at the wideband reading before the sensor has a chance to warm up. the PLX the output is 14.5 or so until the sensor warms up.
Bob
Dave, here's a short video I took this morning.
