replacement ramchargers fan motor?
mike86ttype
LOW ALKY!!! AGAIN?
Has anybody found a replacement motor for the ramchargers fan. One of my fan's motor is out.
Just buy a new set from GBODYPARTS and make sure you have a relay. I think they are around $90. My 2 cents. Brad
Just went through this and the only one is.....??
G body parts, but get this.
I installed my new ones with the Caspers Hotwire kit that is supposed to eliminate the motor volt drop that supposedly burns em up and the pass side fan motor is already starting to squeak as it is coming to a stop. They are not even 6 months old.
Good luck
If these go out I will have to sell a kidney a get the Spals or equiv...LOL
Do yourself a favor and buy the Spal dual fans...it cost more but you will probably only have to buy fans once. I used to have the Ramchargers fans and they crapped out on me in just over a year. Seems many folks have about the same lifespan from these motors as I did. By the time you bought 2 of the RC fans you coulda bought one of the Spal fans. I got mine off ebay brand new for about 180 bucks from one of those ebay stores. And I also got Caspers dual fan relay for the Spal fans. Also I tried looking up the fan motors only for a Dodge Intrepid to replace my old Ramcharger ones and they're like 140 bucks each.
Make your own brackets....Sorry I had to sound like a smart a** but it's true.
Jason
totally understand. sorry for makin u spoon feed me. somebody should make a how to. maybe it will be me but its winter time and i really only need one fan on my daily drive. thanks for ur help
ok here is how I made mine. You know how in desks that have file cabinets that have those bars that hold up the files? Well my desk had like 10 of them so I used of those. http://www.glassblower.info/images/ferritti.jpg Thats what they look like. Then I simply cut and bent the bar to fit into the stock fan location holes. No zipties of force fit here. I drilled a hole into the plastic fan moulding and just attached them there. I will see if I can get a pic.
Jason
Well I couldnt get any decent pics of the brackets on the car. I'll try to get some of them off.
Jason
if you just need a motor go to your local dodge,chrysler or jeep dealer and get it off a lh intrepid model around 00-02, thats what the fans come off of.
Good luck
If you bought these from me send them Back & I'll send you a new unit. Has to be a manufactures defect. We buy enough I should be able to get it returned.
Chris McDade these are the same as the old ramchargers fans.
