turbofrank
- Nov 4, 2002
This thread is old
SignUp Now!View attachment 285430 I am looking for any advice on getting original injectors out of intake
I've read about screwdriver pry up on rail, nervous to put that kind of strain on rail
I've read open end box wrench, I'm having trouble getting any good leverage
I am trying to remove entire assembly with injectors still on rail
I have unbolted the rail, removed ignition module, cables, etc
Having hell of a time lifting it out, I've wd40'd
Hoping that will help
Any other advice
Here's a couple of picks on bits I've seen others question like the electric connection to harness
Joel
Hi rulesWhere you experiencing knock before the injector install & if so how much? Also was this the only change you made to get to knock free status? Thanks for the detailed steps thru the process of replacing the injectors, make me feel like I can tackle this job as mine are the original ones.
