replacing te63 what turbo to get
I think it's time to replace my te63 and I want a billet one what turbo should I upgrade to to go faster on a stock bottom end I been as fast as 10.69 @126 1.50 60ft and this is a street car thanks for the help
You've only trapped 126mph so far. Your current turbo isn't close to being out of breath. You may pick up a slightly quicker spool but boost will need to be increased to increase power. The MFS 6265 is a winner for a 130mph application with heads and cam and boost under 30psi. Of course the valvetrain needs to be stable and the converter has to be a quality unit or you won't get the most out of these turbos
BPE2013@hotmail.com
I got a ptc 9.5 so I'm good there and I'm looking to get some more mph so I should turn it up cause I'm only at 21 psi now so I'm trying to get low tens on this motor
Before my Te 63 gave up ( shaft play) I was running 10.51. I had no intentions of ever changing it. I think that there was a Te63 and a 63e which I believed had the actuator on it. I had the .85 housing and no actuator, no tap on the compressor housing and two delta gates. Everyone called it a big shaft turbo. You are moving pretty good with a turbo that has been out since the late 90's. ( Mine was from ESP in 1996) By the way you, mentioned "stock bottom end", no caps or girdle? Rolling the dice....(I hear ya). I was told that the turbo was good to about the 10.30 - 10.40 range.
I'd say it's good to 10.0 with today's converter technology
BPE2013@hotmail.com
If there's nothing wrong with it then there's no point in doing anything to it. It's a typical e cover. Not ideal but not hurting anything right now
BPE2013@hotmail.com
