Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
The cushion room B-cast sheet was hog ringed to the back of the upper section of the rear seat. Remove the bottom cushion of the rear seat, remove the two torx bolts securing the retractable seat belt on each side releasing the bracket for the upper cushion. Once done, lift the upper cushion toward the roof a few inches and remove the cushion.I didn't have one under the rear seat. Only the door
If no one has been there before, that is where you will find the sheet. It is not visable from the trunk as there is the filler fabric and sound proofing material blocking the view of the back of the seat.
