Restalled d5 slip
85tr
Was curious what I should expect for a 2400@0 psi restalled d5 unlocked. Car should run high 11's. Thanks.
28" tall tire. If anyone has checked slip at the end of the track in third gear with a restalled d5 I would appreciate any input.
Charles what do you think I left out ?
If I recall correctly, my stock D5 slipped close to 20% running low 12's. It wasn't re-stalled or anything.
I don't think anyone has really looked into the slip with 12" converters. But "slip" is a function of several variables and is dificult to predict without more info on your car setup, RPMs thru the traps, etc.
In my opinion, the restalled D5's work pretty well at that performance level, and if you want to put the best number on the timeslip, you can always lock the converter.
Bob
