Just a question....stock rotor and vanes are in good shape on my rebuild. Should they be replaced anyways while the pump is apart? Did the rest of the pump mods per the ck-performance book.
Do not replace the rotor and vanes unless they need it. Only replace the failure prone cast rings. When changing the rotor and vanes you need to clearance the assembly. Contact chris at CK for a 200 4-R manual.
I do indeed own this fine book. I just wanted to make sure before I put it all back together. All the clearances are as recommended. New steel rings are in. All my parts came from CK.
