I have an 87 T and the trans is acting up. The reverse stopped working all together the last time I drove it. I have not noticed any problems up until then with anything in the trans. It seems that all the forward gears are there but you have to let out on the throttle to get it to shift into the gears. That problem started at the same time that reverse quit. I don't see why reverse would just quit but that is what seems to have happened. Is there anything that I can check or have checked that may be making the trans do this? Any help would be appreciated. Thanks,
Josh
Josh
