I've got an EA Stage 2 trans that's shifting too late at WOT. It's going to 56-5700. I can feel the engine lay over, so it's getting out of the power range for sure. Stock heads, 206 cam, ta49 @ 21 psi.
I first thought I was driving thru the converter ( Rev Max 9.5" 2600 LU) but I get a good 8-900 rpm drop on the shifts, so I don't think that's the case. Am I correct?
So, add weight to governor via spot weld or what??
I have also verified TV cable is set perfect.
Thanks for any help.
Sent from my SCH-R970 using Tapatalk
