having a problem with my gn. i got the car a couple of months ago so i am new to turbos and computer controled engines. i had to get the motor for car got it put in and running. the car is running very rich. at start up it has black smoke comming out of tail pipes. after warm up it runs a very hi idle. about 2g
after test driving car i got a 23 error. replaced the mat sensor. i also replaced the o2 sensor. i still got the 23 error so i replaced the tps. that fixed the 23 error but getting a 22 error because i have not set the postion of tps yet. i have a stock chip from turbotweak. stock inj street 93.
the car will also start running very pooly suputers and almost dies. if i turn off car and restart it fixes it. it reports no code with this. i checked fuel pressure it is 32 pounds idle 45 with no vacume. the only thing i am not for sure about is if i have stock injectors. the numbers on inj are d1720ba fj24 1783. they have a blue ring around them. are these stock or aftermaket replacements and would i have to replace prom. is this causing my rich condetion.
