T turbogray Active Member Joined Nov 9, 2009 Dec 17, 2013 #21 RICHIE HIGH PSI said: ??WHO is using a 2.0 gear?? I use stock gear ratios in tranny. Click to expand... righttttt?
H HighPSI Moderator Staff member Joined May 24, 2001 Dec 18, 2013 #22 You guys can believe what you want. This is a stock stroke engine with a standard gearset TH400.
W we4Mateo Double you eee what? Joined Apr 7, 2010 Dec 19, 2013 #23 HighPSI said: You guys can believe what you want. This is a stock stroke engine with a standard gearset TH400. Click to expand... Some can't believe that it's possible without voodoo. Posted from the TurboBuick.Com mobile app
V V6RACER The true 8 Second 109! Joined May 30, 2001 Dec 19, 2013 #24 I believe it... Just more proof that you can run 8s on a stock block without custom one-off parts. All in the tune & suspension.. I'd like to see the slip
M Mike E Mr. Badwrench Joined Oct 9, 2006 Dec 19, 2013 #25 V6RACER said: I believe it... Just more proof that you can run 8s on a stock block without custom one-off parts.... Click to expand... A stage 2 block and custom parts will only get you a 9.26.
V V8killR4U Active Member Joined Jan 21, 2003 Dec 19, 2013 #26 what kind of trickery is this.....lmao
G GetOwnedVette Active Member Joined Jun 13, 2006 Dec 19, 2013 #27 Some of you guys amaze me......stock 109's with 70 trims doing what some guys with stage 2s and way bigger turbos cant. Simply amazing. Keep pushing it to the limit gentleman!!!
