SignUp Now!lets say you have a stock GN and want to do this would it have to be chipped for it or would it run fine without it??
Wow that looks great, is that the RJC pipe? Also, looks like you lost your translator turbo-6 cover somewhere between pics 1 and 2
Phil-
I just bought the RJC 4" pipe at the Nationals. Couple Questions for you
1. I'm changing to the base translator set up with Z06 MAF and going to use a turbo tweak chip for my 50LB injectors.-I'm currently running the MaxEffort 16 POS thumbwheel with a stock MAF. Will I have to cut the RJC pipe at all to make it fit as pictured on your car?
2. What part number is the air filter you used?
3. Where did you get the adapter hoses on the z06 MAF side? they look like 4-3-1/2?
4. My turbo is a PTE 6152 with a 3" inlet so I have to run an adapter 3"-4" and was wondering if you saw any performance gain once you put this on?
Joe
Where can this Z06 MAF be purchased??? Can you supply GM part number?
JM
