hello; Any stories on this item? I read the ad. and it sounds good but is it worth it to be put on a street car? Do you think it would make the car run any better?
IBBY
I look at it this way,their are some real old grumpy guys on here that go alot faster than me and they use them so it is good enough for meOh and race Jace is very helpfull with all his products
Even if it doesn't make the car faster, there are known flow issues with the stock intakes, which is all I personally have ever run. I've had this plate in since I was running 15psi on my stock turbo and pump gas and still run it now. It def didn't slow my car down in any way, and when I did finally have to pull the heads off, all the cylinders looked the same, which is all I wanted out of it. Some say there are problems running them with a lot of alky, but I have never experienced any. I've never ventured to truly test my car without the plate as I see no reason to verify it by taking a step backwards.
