SignUp Now!convertor is new the old one still had 1/4 inch to pull against the flexplate. my oil psi was 50 and 70 cold and 35 and 55 warm.?????????????????????Steve V said:Possibly your convertor ballooned for the thrust. The copper issue....what was your oil psi? If the crank looks good I'd rebearing it and let it eat until your ready to lay down some cash for a total rebuild. Possibly your front cover is worn in the oil pump area so oil psi/volume is low,or front cam bearing is toast....
knocking noise when i revved the motor also when i took the lifters out they all looked good exdept number 3 exh. has a little circular wear nothing majorSteve V said:All that sounds good......why did you investigate?
lpaulabbott said:all bearings are showing copper why? motor only has 65,000 original miles thrust has .032 play
why not keep the double roller also what do i need to do with the thrust?another thing is they still put the tensioner on the double roller i thought you were supposed to eliminate thatSteve V said:Since your cam bearings look good,just replace the rods and mains,get a stock style chain. Check the oil pump for clearence and wear. If in doubt replace it. Not sure that new mains will get that thrust back in spec(.003-.013).
