I've been re-reading Smokey Yunick's book "Power Secrets". The material is a bit dated but the man is a genius.
I was going over the section on rod length where Smokey argues long and hard to use the longest rod that you can.
To briefly summarize, he points out that with a longer rod the piston dwells near TDC longer. He argues that this allows combustion gasses to work on the piston longer. He also says there is a mechanical advantage in that the crank arm swings over further while the piston is closer to TDC.
This got me thinking.
With a longer rod you are imparting a force at a much more obtuse angle to the lever arm of the crank.
With a shorter rod the angle becomes less and you are imparting the force closer to perpendicular which would in turn give you more leverage.
A simple way of demonstrating this is putting a degree wheel on the crank, moving it to 6 ATDC and placing a weight on the piston. Then you would measure the resulting torque required to hold the crank at 6 ATDC. With the long rod I can almost guarantee that the torque required to hold the crank would be less than with the short rod.
The losses in this system would be the increased friction from the piston on the cylinder wall, and decreased dwell time which would mean that combustion pressure would fall more quickly than in the long rod scenario. The one other potential problem is the possibly increased detonation sensitivity due to the sharper pressure rise in the chamber. Maybe reduced timing lead is all you would need..and in that, perhaps another factor that would improve power (sort of like increasing the compression ratio)
In Smokey's case I can see that at 7000 rpm N/A, the friction generated by the piston wall would become a greater proportion of time that the combustion energy would have to overcome.. so as RPM comes up the power gained from increased leverage diminishes relative to added friction.
But in our engines that run at relatively low rpm, is this a factor? Is there power to be gained from a shorter rod? I can conceivably see how you would increase low rpm torque at perhaps the expense of high rpm HP. But at what rpm does the system start to lose more than it gained? Obviously the rest of the system's tuned rpm range is playing a big factor.
Any gurus out there want to comment on this?
