I have been putting together a stage 2 for the past year. The crank was (UPS lost it) 3.625" and the rods are 6.3" (pin size is .927"), if I use my 3.54" crank, what length rod would I have to use to make the custom pistons work. I am not sure if there are other dimensions that one would need to complete the answer. This block has a short deck height of 9.413" Also would the change in the combo alter the compression ratio (8.75). I think the displacement would change slightly.
Thanks,
Jeff
Thanks,
Jeff
