Roll Bar pics
OK, this stuff drives me crazy. I got out my 2003 NHRA rulebook. The 2003 book is different and more detailed than the 2002 rulebook. Mentions bolt-in's and swing outs specifically (both of which are legal). Ok, here we go.
For Roll Bars from page 202. Chrome Molly bars MUST be TIG welded. It says for mild steel you can TIG or MIG but not for Chrome Molly. John, you should check into this. If he MIG welded your chrome molly bar to the frame it’s not legal. The new rule book is very clear unlike previous ones. Also, roll bar CANNOT be bolted to the floor. This is only applicable for a uni-body car as the car’s body incorporates some of the frame bracing in the construction. For a full frame car like the G-Body the rule book states that the bar must be welded or bolted directly to the frame, it’s very clear. John, looking at the front connection point it’s too far into the center to hit the frame. My cage is welded into the frame (I’ve got the chassis certification to prove it) and the frame rail is directly under the door-sill plate. In-fact my “Body by Fisher” door-sill is notched where the forward bar goes through the floor and is welded into the frame. That’s what that “bump” down the sides of the floor is, the frame is under that. I would look under the front of the car and see if the bar comes through the floor and welds into the frame. The rule book doesn’t differentiate between the connection point of the main hoop and the front supports. Naturally the rear supports can’t contact the frame so they are connected to the body, I don’t think this also applies to the front but I could be wrong.
The main hoop must be within 6 inches of the rear of the drivers helmet but not below it when in normal driving position. Also, must be at least 3 inches above the drivers helmet. Like Chuck and others said, the cross bar must intersect midway between the drivers elbow and shoulder. I would think a tech would give you a few inches in either direction as wiggle room. The rule book does NOT say it must be between the elbow and shoulder, it says must intersect the midpoint between the shoulder and elbow. Again, most techs will give you a little wiggle room.
Honestly John, please check into the placement of the front support as well as if it’s MIG welded in as the rulebook is very clear about TIG only for chrome molly. I assume the chassis guy pushed them inward so they clear the door panels. If you look at many roll bars and cages you’ll notice the door panels are usually notches, that’s how far out the frame is. You obviously paid a lot of money for that bar, I just want to make sure you got what you paid for!
Contrary to what you see in the pictues but the door bars ARE welded to the frame. I will take some pictures for you all to see as soon as I get a chance. And yes the moly was TIG welded. It is legal to weld the supports to the frame by a MIG welder (I dont think W.P. will be able to tell the difference @ E-Town). I must stress that I was in the drivers seat when all the measurments were made. The bar is legal and everyone needs to get over it. If anyone has a problem they can look at his website @ www.theracecarfactory.com or call Randy personally @ 772-219-8860. I just spoke to him since he dosent read these boards, he will be glad to clarify any questions you have. Ya'll have a nice day :D :D :D
Art,
Thanks for your concern.
-John
You go Artie!!!!! Keepin it real from da field with the NHRA rulebook.
Art what if anything does the rulebook say about the bars coming off the main hoop should they be higher or are they ok as is?
Peace
Peace
Making me us my college education… The rule book on page 203 states that the
“Roll bar must be adequately supported or cross braced to prevent forward or lateral collapse. Rear braces must be of the same diameter and wall thickness as the roll bar and intersect with the roll bar at a point not more than 5 inches from the top of the roll bar.”
I read this to say that supporting the roll bar in the rear using the side supports is legal as long as the supports are welded to the side bars not more than 5 inches from the top. Although I don’t think it’s as strong as having the bar supported to the top of the main hoop, it is legal from what I see in the pictures and read in the rulebook.
For a cage it states that the rear brace bars must be installed at an angle of 30 degrees minimum from vertical. I see no such specification for a roll bar so I again believe that the rear bars are legal both in connection point and angle/bend. I don’t think I have ever seen a rear brace installed like that except on show cars where they don’t want to modify the seats or rear deck to accept the support braces but again, they are not racing these cars. I think that’s why the person on the other board asked if it was a show bar.
BTW, I just went out to the garage and felt-up FUR. J Forward from where most bars are installed (at least mine) there is a protrusion from the frame where the frame gets thicker and becomes a box frame vs. the “C” frame that runs the length of the car. This is about in-line with where the forward most door-sill molding screw is. If you were to install the bar tightly through the floor and against the “frame hump” that runs down the side of the car you can catch the frame. Looking at the pictures again I think this is where the front bar is connected on John’s car. In looking it does appear as if there is a section of frame where the front bar can be welded to the frame. I think John’s forward connection point is legal and can be welded to the frame.
I’m still not sure about the MIG welding CM to the frame though. It doesn’t state this in the rulebook and makes no differentiation in either a roll bar or roll cage where the stipulation for chrome molly needing TIG is not needed for the frame connection. I certainly would read the regulation as needing TIG to connect the bar to the frame.
Peace
Also I believe they have to be installed at a minimum angle of 30 degrees from verticle.
According to my NHRA rulebook it says sidebar must pass the driver at a midway point between the shoulder and elbow.
I just had my bar installed last week and made sure I went through all of this info. I don't want to be bounced on a technicality :rolleyes:
Sorry, no pics for you guys to look at though ;) :D
Hey Clayton, read my above post (I know it's long). The 30-degree angle is only mentioned for a cage, not a bar. I was surprised when I didn't see this for a bar.
Looks like its a bolt-in setup for me :)
Yaaaa.... No burning carpet ;)
So swingouts are legal? Good, I'd hate to climb over that crap.
I noticed that too but I would have to ASSume that it also stands for a 5 point bar? Doesn't make sense otherwise? :confused:
Mike, swingouts are okay as long as they are done within spec for the hinges and clevice etc.
Good to hear you got your bar installed:)
Does this mean you are going to go after Mike Prices 10.81 ET on a unopened motor? I forget has your been opened up before?
You get used to it. I knew they were always legal for a bar, I was surprised to find specifications for swing-outs for a cage.
You get used to climbing over it real quick, not a big deal.
I was surprised too.
John has a cam and Champion ported iron heads.
I wish I didn't get swingouts. I never use them and its just another thing to rattle when you hit a bump. I'm having them removed when I add a couple of points.
WHT87T, I don't think anyone is jealous of your cage, or has a personal vendetta against you, I think people are trying to give you their personal opinion and experiences based on YOUR pictures. I know personally , the comments come from well educated enthusiasts that have done their homework. Like it was said on the other board, if you didn't want people opinions on the bar, maybe you shouldn't have posted it. I know personally I would be wrting all this down and calling the installer to make sure everything was OK, and thanking the guys on the board for looking out for me and my safety.
Track techs aren't rocket scientists, they are just like some of the people commenting on the board here. I hope the attention of this thread at least gives you the ammo to successfully argue that your bar is legal if in fact it is. I know Jack Cotton had to explain the rules to the tech for me to get me through tech, something about the swingouts.
GNSCOTT
I'm glad there's people out there that are lookin out for my well being. Its just how they approach the situation. I only know a hand few of members personally on the forum. Some people just jump to conclusions very easily without investigating the situation. I knew the bar was legal the minute it came out the shop. Measurements were taken with me in the car and I had the rulebook in my hand. I wish some people had just asked some questions first before insulting my knowledge of the rules and my chassis builder as well. I decided not to go with swingout because it will compromise the intregity of the roll bar. The builder didnt even want to put them in.
Art
The motor still hasent been open up yet. It still has the stock cam in it. The car went 11.30 @ 120 with 20psi and a 3psi launch poppin goin down the track b/c the 009's couldent hold up.
Geno
I've got bigger plans than that. I'm gonna try and chase down Jason Cramer and the Bampherts in TSM. Wish me luck.
Everything is installed and looks pretty good IMO. I hope I can chase down Bill @ Turbo Thunder but I doubt I will try for Mike's 10.81 ET unless I can drop about 300 lbs. ;) My car will be about 3650 with me in it and I think Mike had said previously his was about 3300 with him in it. I Don't think I can make up that kind of difference, especially runnning a smaller turbo. But to answer your question, no my engine hasn't been opened up.
Art & Wht87t, I'm pretty sure Geno was talkin' to me. ;) :D
I've got bigger plans than that. I'm gonna try and chase down Jason Cramer and the Bampherts in TSM. Wish me luck. [/B]
>>> Good luck, you'll need it and its Dusty Bamford not Bampherts, also if you're gonna chase these two very good and well experienced racers who have accomplished alot and running in the 9's you'll have to add a front hoop to you roll bar but I am sure you knew that already cause you got the rulebook.
Best of luck
Hi Scott,
You're right, I cut and pasted wrong. I just deleted it.
Sorry again.
Holy cow!!!!! your going from a 11.30 to a 9.8ish???? Please tell me your combo..
That's a pretty big jump. I would like to know tho..
Jim
New TSM motor, TH400, and a F.A.S.T. Cal said it has the potential. Only time will tell. I dont wanna disclose any details at the moment.
Welp, Good Luck then......
