roller bearings
mygn276
Ok does anyone know what size roller bearing to use in stage 2 block? Spun the cam bearings and need to know what you did to to make these work? Thanks
Easiest option is to bore the block from stock to 2.0472+- and use a 45 x 52mm bearing. Standard cam is 1.785 that you will need to grind the bearing journals to 1.772 or 1.771 if bearings are a tight fit in block. So basically you just grind .013" off the cam bearing journals only!! The cam lobes will work through even though they are bigger than the bearings. I have these bearings in my stock if you need some. $80.00 shipped to your door. Mike:cool:
