I posted this in tech , thought I would give it a try here
Twice when spinning the tires hard the eng. has backfired and quit running and will not idle, If I get the car restarted and unplug the cam it will run ok . Rechecked the cam sensor and it is out of adjustment , WAY OUT . I tried a diff cam sensor after the first time and the same situation happened again , hard tire spin ,backfire and the car will not run barely idle until I get the cam sensor unplugged .
Could the cam sensor itself be moving ? I checked the tang on the ring and it is not broken . Could the gear on the ROLLER CAM be the problem ? Jumping teeth? Gear come loose from the keyway? I may be hitting the rev limiter and that is why it backfires all of the sudden , could the backfire move the cam sensor ?I checked both cam sensors over and seen no problems with them .
Mark
BTW I Just took the car for anothe test drive and it did it at 12 lbs of boost and no wheel spin ,car ran great and at 12 lbs boost nd lite accel it backfired and would not run properly till I unhooked the cam sensor , I guess the frt cover will need to come off
Mark
