I purchased a 210-215 hydraulic roller. I have champion ported irons, ported stock intake, Harland sharp 1.55 roller rockers, TE60 turbo, 3000 stall converter 60lb motron injectors. My ultimate goal is to run into the high tens eventually. I know the TE60 probably won't get it there but is this cam too big for my application? Last year with a flat tappet 210-205 cam and the same turbo my car ran the best of a 11.20 @ 119mph at 24psi boost. I don't want to get too big of a cam that makes the car lazy on the bottom end.
This is a primarily street driven car with occasional track weekends. Ive had alot of guys say go with a comp. 206-206 or 212-212 etc. Why is the duration more on the exhaust compared to the intake? I always thought in a turbo motor you should keep the intake and exhaust at the same duration.
Maybe im wrong.
Any insight will be helpful.
Maybe im wrong.
