Jan 8, 2006 #1 V V6RACER The true 8 Second 109! Joined May 30, 2001 Messages 2,890 What should I shoot for on camshaft end play?? I searched here and haven't found one direct answer..
Jan 9, 2006 #2 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 Play .004-.010---measured off back of cam with dial indicator.
Jan 9, 2006 #3 V V6RACER The true 8 Second 109! Joined May 30, 2001 Messages 2,890 Lee Thompson said: .004-.010---measured off back of cam with dial indicator. Click to expand... I measured .006" so I guess I'm good to go..
Jan 9, 2006 #4 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 Tighten up I have had them tighten up 1-2 thous. after sitting as the gasket maybe compressed--You are good. Don't look back.
Jan 9, 2006 #5 C CTX-SLPR Active Member Joined Feb 4, 2004 Messages 1,942 So put the cam in and the timing cover on then check in the rear gallery plug hole with the dial indicator?
Jan 9, 2006 #6 N NCTURBOS Gettin' back in action!! Staff member Joined May 26, 2001 Messages 3,951 CTX-SLPR said: So put the cam in and the timing cover on... Click to expand... You must have the frt. cvr. gasket in place and the timing cover torqued/tightened down to get an accurate measurement. K.
