I am curious to know if you have had this issue since the rebuild years ago?
Anyway, leak the motor and report back the findings.
Additionally if you still had the heads off the car I would disassemble the valve train and see if the valve guides are worn. This may also lead to your problem. Slide the valve up and down in the guide and see if there is any slight wobbling. The valve should locate itself in the guide and move without resistance but it should not have any play from side to side. If it does you have a worn guide.
Mad Trbo yes I have had this issue with the car since it was rebuilt years ago. I think it was masked for a while because it had a TE-44 that had a bad seal and smoked like crazy. Put a good turbo on and I thought it was fixed, but I still had the intermittent smoke at idle like I do now. It's kind of odd sometimes it won't smoke at all, but when it decides to it is alot of smoke out both pipes, only at idle or after a long decel.
When I put the valve springs on a few weeks ago I saw the broken stem seals and thought that was it for sure, so I didn't check all the valves for side to side play, just a couple and they seemed ok.
I am going to drive it the rest of the week with the PCV blocked, and if it still smokes I'll do the other tests like you said. Thanks for the help and advice.
Ok blocked off PCV and it still smokes. I am going to do leak down and compression tests this week. If those check out good I guess it has to be valve guide seals or turbo.
jpwalt my turbosaver is from '99 so I assume it probably has the larger line on it. I don't know how to tell without some 3 or 4 an line to compare it to. A few months back I put a .065 restrictor on the feed line right before it goes in the turbo. But maybe a seal has already been damaged?
Remvebeforeflight I did find some of oil in the PCV hose, so I am just going to leave it blocked until I get this solved. Then if it continues to be a problem I'll do something like you did or try a different gasket, thanks.
Thanks all for the advice. Hope to get it figured out soon.
