BLACKHAWK38
- May 26, 2002
AM having fresh 109 build, block has been bored, aligned honed crankshaft apeture;
018 total taken off block and heads,
Thinking of using steel shim head gasket.
1985 HOT AIR intake manifold going on this engine
Using 188/188 .403 lift crylogenicly treated REED cam and REED rocommended valve springs that also get the cold shoulder.
I was told by machine shop that stock length (8.963") PUSHRODS should work fine, but I did not REVEAL that I may use thinner head gasket.
NON-Adjustable STOCK STYLE rocker arms will be used along with GM lifters
PARTS NEEDED AT THIS TIME,set of 12 CHROME MOLY PUSHRODS stock length 8.963" (12)
ROLLMASTER TIMING SET< THE GOOD ONE, I mean the BEST ROLLMASTER for buick V6 even fire,
FRONT TIMING COVER, NEW GM ( GM, not copy
cat and NOT DEEP OIL PUMP GEAR POCKET and NEW GM OIL FILTER COVER with nipple
Please advise where to buy from VENDOR on this board.
THANK YOU , BLACKHAWK 38
