- Dec 15, 2002
I'm going to start on this earlier than I thought, next weekend.
I found a new Dynojet shop not too far away and will do my normal M15 post turbo Meth run and then two additional runs with the M2 nozzle and then M3 nozzle preturbo and see what happens to the graphs. I have a feeling I might need to lean it out some in the TT chip at WOT so I'll do a bunch of street runs with the wideband to see what happens to the AF/R's and then adjust if needed to make it similar for all the runs.
Not sure if I'm going to do it at 28psi with my race chip or at 22psi and my street setup though. I'm thinking I might go 28psi, 27 degrees with straight 110 and Meth to get the best idea if it's really pushing the turbo map since the 49 should be maxed out around there.
I'm going to mix a 50/50 of Meth and Distilled Water, that mix was kicking butt with the Diesel crowd.
BTW, I guess the TA49 is a 60 trim turbo, that's pretty small for us IMO.
I'll hit this back before I go and do a HP/TQ guesstimate before and after.
