Took the car out for a drive yesterday after not driving it for a couple of months. Prior to this drive i installed a double pumper, fuel filter, new plugs, and dialed down the boost to 17/18psi. I filled up the Alky tank and away i went. Car felt strong but had alot of knock, so i pulled over and upped fuel in the chip +5%. Took it back out and still knocking. Then i turned up the alky gain knob to 7 1/2, and still got knock. I headed home at this point to grab a bite to eat. After dinner i upped fuel in the chip to +9% took her out and still got knock. On that run a recorded a PL file. When i got home i let the car cool off and pulled some plugs to my surprise they were WHITE as a ghost
. I was checking out my Double Pumper install and noticed I forgot to groung the black ground wire where the pump drops in and connectors from the pump and hotwire go together
.. Was this not being grounded causing my problem. I can hear the first pump kick on when i turn key on ignition. And i have 40psi of fuel pressure at the rail(vac on).
Here is the PL file
View attachment blast.dat.zip..
Let me know what you think.
Here is the PL file
