s-10 brake ?
Lee Thompson
Is there a difference in the spindle and calipers between the 2000 S-10 2WD Balzer and Pickup? If so, what are the difference?
From what I understand the Pickup is a single piston caliper and the Blazer is a dual piston caliper. I believe the spindle would be the same, but I don't know for sure.
HTH
David
Spindle and brakes are different. The trucks use the same spindle and brakes as a G-body. The Blazer uses the newer FWD style. It uses a 2 piston caliper and it has the FWD type sealed hub and bearings with a slip on rotor. The rotor is slightly larger. The Blazer setup suffers from the same problems as all sealed hubs have and IMO make a poor choice for a brake upgrade because of it.
