Ok. These brakes from summit. (snowbird) They're a bigger piston diameter. By how much. What was the stock diameter? Do these make that much of a difference?
And, I hear that they increase the heat on the rotor a little. Tell me this then. I had cross drilled and slotted rotors on my car a while ago, and I can tell you without a reasonable doubt in my mind, that they made my braking WAYY worse. It was totally noticable. I was told that they did that due to the decreased braking area (from the holes and slots) and that certain pads, work the way they're supposed to, at a certain heat range, and that if they don't attain that heat range, they work with less efficiency. Anyone else heard this?
What I'm asking is, due to the increased heat from those calipers, if I were to go back to drilled rotors again, would that just negate the gains I made if I got the better calipers?
