S II engine
dentmasters01
Stage II 4.1 block. 016 casting.
4.030 bore
Sonic checked with 2 sleeves.
New buick crank. stock stroke.
Wiseco forged pistons
childs-alberts rings
edelbrock roller chain
comp cam 212-212
comp cam push rods
champion p/p heads
ramcharger cover
arp main and head studs
arp rod bolts
flow cooler water pump
buick rods polished shot peened and mag checked
It runs strong, but has aquired a rod knock. Needs new bearings and prob. crank polishing. At the worst turn the new crank 10
7300.00 intake to oilpan
May sell heads seperately if anyone interested for 1000.00 and block price will be $6300.00
new pics
here are a few pics
more pics
are you sure thats a stage block? i dont see the area where the extra 3 head bolts go on the outside of the heads. should have the turbo 6 emblem next to the part number also. just wordering?
It appears to be a stage II block to me. The extra material is there for the headbolts, and it has the front boss plugged for oil feed. A stage 1 has that milled off and un taped. :)
sorry. my bad
Stage 2 off center,On center normally has the front oil fitting on an angle
For all those wondering, the #'s on the block are
25500016
Its a SII with turbo 6 stamped on the block.
I never ran it. It was in my custom 72 chevy pick up. (which by the way is forsale with a complete stock buick turbo drivetrain.)
dollar_bill said:
Are the rods and crank regular cast Buick pieces and is the cam a roller or flat tappet?
factory buick rods polished shot peened and mag checked
new buick crank stock stroke
