Scan master G for XFI
tonysmach
When I try to run a ScanMaster G for XFI simultaneously with eDash, I get an error. Is there anyway to run them simultaneously? SM G works fine when I disconnect the eDash.
how are you connecting them? you can't share a port.
what error are you getting?
Bob
edash on com 0, wired in to C30 TX C31 RX D12 gnd with the supplied duetsch connector ,
scanmaster plugged in on the laptop metripak connector com 1 C27tx C28 rx C29 gnd
normally when you have edash connected and connect a laptop the edash disconnects then reconnects no issue ,
with the SM-G edash on and connected plug in scanmaster and scanmaster comes up and edash disconnects and tries to reconnects but then displays error 1 check connection
as mentioned unplug edash and SM-G works fine , unplug SM-G and edash works fine
the Scanmaster is probably polling for data too fast. Let me see about slowing it down a little.
Bob
Here is the error message I get on the eDash after about 5 seconds of both eDash and SM G for XFI running. The SM G restarts about every 5 seconds when both are running.
likely the scanmaster G is talking to the XFI too fast. if you are set up with bluetooth, I can send you a file to flash into the gauge to try.
Bob, can you list the steps to connect the SM G/XFI to the laptop. I am not the best with computers. Shouldn't the name of the device (The SM G) pop up somewhere on my laptop?
thanks.
Tony
I am also having the same exact issue running the scanmaster G and the edash. I can only use one at a time or else they just keep resetting. They are both on separate comm ports. Is it possible for you to email me the flash for the scanmaster to allow both to work?
the fix I had did not solve the issue. I need to change the communication strategy. Its currently pulling a lot of data from the XFI, and I need to cut that down so the edash stays happy.
I should have something soon, but send me an email as a reminder.
thanks
Bob
thanks
Bob
Awesome. I’ll check in another month or two to see if you have an update.
I just finished something that was taking all my time, hopefully I can dig into this shortly.
keep reminding me
Bob
