Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
You need an adjustable fuel pressure regulator. TT chips use 43lbs of fp at idle with the vac line off. You need a fuel pressure gauge on the fuel rail to set that. 30 lbs of fuel pressure with boost is a recipe for disaster, especially with no accurate boost gauge! Your IAC numbers are off as well. Here's a quick reference for the settings. Quick Reference Page For the '86/'87 Turbo Regals and '89 Turbo T/A When you adjust the IAC is will most likely change the TPS as well. You have to go back and forth to get them in sync. There is instructions for adjusting both on the .org site. That might fix your idling issue. Check all around for vacuum leaks too. Do yourself a favor and disconnect the wastegate actuator until you get the afr so you don't go boom.
