NoVA_87_GN
- Jul 12, 2022
So I finally got a Scanmaster G in my T-Top. Here are the readings, hopefully you all can tell me what exactly I need to be looking for.
Some info about the car, new fuel pump, hotwire kit, 60 lbs injectors, TT chip, new injector harness and injector hotwire kit, new plugs, accufab afr, I believe PO replaced the MAF sensor.
This was at idle with car warmed up.
Mv 534
MAF 5
LV8 31
Volts 14.1
INT 28
BLM 142
RPM 825
TPS 0.50
IAC 27
O2 CC 86
Trouble Code No codes present
Thanks for any input
Mv 534
MAF 5
LV8 31
Volts 14.1
INT 28
BLM 142
RPM 825
TPS 0.50
IAC 27
O2 CC 86
