Scanmaster help
If you haven't seen this, it is a good guide.
http://www.gnttype.org/maint/basics.html
Vacuum leaks are a pain to find. But this easies way is with a can of brake clean. Just start spaying over areas around the intake and vacuum lines. If and when the idle changes (usually stumbles), then that is the area of concern.
You should install a 160 stat in there The car will run cooler and less prone to detonation.
Not a fan of the 195 in these cars. Is there any Buick guys in your area??
No there are no buick guys in my area. I'm starting to wondering if it's the turbo tweak chip.
