TheGovernment
- May 2, 2010
I finally got all my mods put in my 86 regal T.
60lbs injectors, TT chip, High flow pump and hotwire, 3" DP, TE-44, cold air intake, FPR set at 39lbs vac off this are my readings at idle :
O2 - 820
KR - 0
AF - 05
L8 - 33
bat - 13.2
Int - 128
BL - 129
Clt - 188
Ats - 114
tps - .38
IAC - 26
cc - 163
I got about 6 knock on a pull and haven't tried another until I make sure the numbers are ok and turn down the boost. The o2 seems really high, would that be a cause of the knock? Other than that it seems to be running pretty good.
O2 - 820
KR - 0
AF - 05
L8 - 33
bat - 13.2
Int - 128
BL - 129
Clt - 188
Ats - 114
tps - .38
IAC - 26
cc - 163
