scanmaster numbers
jerritt
ok so this is the secound start up of my 87 gn since rebuilding the motor and fist time with a scanmaster so im not really surewhat im looking at or how o adjust wat is wrong but here they are
AF-20
L8-75
BAT-14.2
INT-128
BL-128
MPH-0
CLT-82
ATS-64
r-1400
tps-.10
IAC-120
cc-anywhere from 05-208
MAL-22
o2-400
knock-0.0
right now im just trying to get my check engine light off so would that mal code cause i chck engine light to come on? any tips or pointers will help me out a lot thanks and while you guys are replying i will be reading the vortex buick site.
thanks again jerritt
AF should be no higher then 07 at idle and the tps should be set at about .43 at idle. IAC is WAY too high. again, allow it to warm up first and then post the numbers again
