Hey guys..........as ive posted on another topic, my car is running kinda funny. It starts, I let it run and 20 minutes later, it stalls out. It then wont start again until its cooled down which is usually 2-3 hours later. When it runs, its fairly smooth. When it was running a few hours ago, I got the following readings from the scanmaster at idle. Are these readings where they should be?
O2......171-850. The levels kept fluctuating (normal or not?)
AF......06
L8......42-44
Bat.....14
Int......128
BL.......128
Clt......103
Ats......71
RPM......775-875
tps.......44
IAC.......78
CC........09-119 (it kept climbing and starting over. not sure if thats normal)
mal......23 (never changed a sensor after swaping the ECM to an 87. I was told I didnt need to)
Also, the gas in the car was old. It had sat for a year without being started with 1/2 or less of a tank. After it started doing the stalling thing, I siphoned the tank and added some "fuel additive" and 20 liters of fresh gas.
Also, the general thought was to check for spark. What am i suppose to check and where?
Thoughts?
AF......06
L8......42-44
Bat.....14
Int......128
BL.......128
Clt......103
Ats......71
RPM......775-875
tps.......44
IAC.......78
Thoughts?
