scanmaster readings !
Parr30
i got a scanmaster 2.1 and I wrote these readings down . can you let me know if there good or bad or need adjusted .thanks jay
AF 03
L8 25
INT 150
BL 150
CLT 193
ATS 113
R 800
TPS .26
IAC 41
NAL 44
this was in park and car idling ....
Iac is a little high but you're tps is low so open the throttle set screw a little and see where you get. Code 44 is a lean code.
Sent from my HTC6535LVW using Tapatalk
Vortex buicks is down again right now but I think if you search, you'll find an alternate link. Learn that site inside and out.
